Picked up this old scope at a thrift store for $10. Couldn’t resist. Powers up, but does not give a trace on either ch1 or 2. Ch 3 and 4 work seem to be normal, but have limited controls c/w ch 1-2. Have full range on the screen and show a trace that has vertical adjustments. Displays signals from both channels.
On ch 1/2 pressing “trace finder” shows the trace at the very bottom of the display. “Inverting” ch2, and pressing “trace finder” shows that the trace is now above the very top of the display. Vertical adjustment has no effect. The selection voltage control seems to work. Selecting all 4 traces only shows ch3 and 4. “Trace finder” shows the missing ch below the screen. Inputting a signal does not change anything- “trace finder” shows the same flat trace.
Have the service man and checked out all of the power supply voltages which are all within range. I do not see any obvious damage or leaking caps. Not sure where to start looking (and I am sure I am in over my head...)
Should I put a signal in and try to trace it?
Thanks if anyone has any thoughts.
Stay safe.
D
