Hi!
If you're only getting a dot, this could be the timebase stalled, the auto–trigger circuit not working or failure of the horizontal (X) deflection amplifier!
We need to begin with the X amplifier to begin with, so first of all try the following simple test:–
Connect one end of a 10k resistor to the positive terminal of a 9V battery, connect the free end of the resistor to the centre of the CH2 input of your 'scope, then connect the negative side of the battery to the outer side of the ch2 input, switch ch2 to 2V/div, and operate the "XY" function – if the X amplifier after the XY pickoff is operational, the spot should move about five divisions to the right.
If this test passes, everything after the XY pickoff and before the X deflection plates is operational!
If there is no movement, either the XY selection or the X amplifier has failed, so please try this test first and get back, whilst I run off printouts of the schematics and study them for you!
Chris Williams
PS!
How anybody could make such an absolutely atrocious bloody job of scanning what was originally a high-quality colour-printed document is beyond my comprehension - I did get to see an original factory Hitachi-Denshi scope service manual (not this model unfortunately) about 8 years ago, and I know they were very high-quality documents produced with coloured pcb layouts and coloured waveform diagrams!
The only hope of being able to resurrect the information lost in that atrocious scan would be to have one of those scopes, de-populate and scan all the PCBs, trace over them or scan both sides of the bare PCBs, then take and draw all the original waveforms again from a working model!
