Hello everybody,
I'm revamping my electronic repair hobby, I realized I have quite a lot of old stuff around me that I can fix and save fro the landfill, so i invested in a new soldering station, ESR meter and some other tools.
It then come to my mind that I still had in the office a 20y old 30MHz portable digital oscilloscope I left aside for 10+ Years.
So what is more appropriate to start the landfill saving hobby with a tool I can use for the future projects?
Now comes the product description: the Hitachi VC-5430 is a digital portable 12V or internal battery powered dual traces 30MHz 30MS/s oscilloscope. It does not sound much but 20y ago that thing was really cool.
I mainly used to troubleshoot automotive components, mine is dated 1994 on the mainboard, it is still in pristine condition but developed a strange behaviour during it's inactivity.
Fault description: The waveform is not clean, on both channel (grounded inputs) a dip is present, it's amplitute des not change with V/div and the frequency is not stable. Or maybe the noise comes in after the trigger... mmmm...
However I imemdiately replaced all power supply trough hole electrolitic apacitors, which all turned ot to be ok with the ESR meter. The only one bad was the 1F 5V memory supercap.
Problem is still there, I checked the voltages ot of the DC-DC and those look ok with the DVM, the scope works so no surprise the voltages are within tolerances.
I downloaded a service manual for the VC-5430 but that cover till 1993, my 1994 mainboard PEG-14 is not covered.
I surely need to troubleshoot more, I was wondering since this problem has a visual clue, if any of you may have an idea of what to look for.
Photos of the problem here:
https://www.dropbox.com/s/cr94t0p3wm42wtv/2015-02-17%2022.43.59.jpg?dl=0My next to do list is:
1. check SMD elcap with ESR meter
2. check power rails with my working oscilloscope at work
3. check A/D Voltage
4. scope the analog input signal path
Any suggestion is welcome!
