Electronics => Repair => Topic started by: salil on February 09, 2015, 10:11:03 am
Title: HM1800 BT Headset refuses to run off 4v power supply instead of li-ion battery?
Post by: salil on February 09, 2015, 10:11:03 am
I removed the single cell li-ion battery soldered to the circuit board of a Samsung HM1800 bluetooth headset (http://youtu.be/jHOQLcOvhR4?t=17s) and replaced it with a 4.1v DC power supply.  Unfortunately, the device refuses to power on reliably.  I got it to power on once or twice, but it was performing erratically.  I put the included battery back and it of course works just fine.   I'm using a 5v/1A power supply and stepping the voltage down to 4.1v with an NTE956 regulator and some caps & resistors.  The current draw when using the battery has never exceeded 0.5A when I measured it.
Does anyone have any idea what could be going on here?
Title: Re: HM1800 BT Headset refuses to run off 4v power supply instead of li-ion battery?
Post by: janoc on February 09, 2015, 11:11:16 pm
4.1V looks quite high for a single Li-ion cell. Those are around 3.7V usually. Are you sure you are not giving it too high voltage?
Post by: Alex Eisenhut on February 10, 2015, 02:59:20 am
3.7V is the nominal voltage. Fully charged they go to 4.2V.
Post by: Alex Eisenhut on February 10, 2015, 03:02:46 am
What's with the unrelated video link?
Post by: amyk on February 10, 2015, 04:18:49 am
Apparently it's what he is trying to use the BT headset for.
It could be drawing far more current than 0.5A in brief pulses, which can't be seen without a scope.
Post by: Alex Eisenhut on February 10, 2015, 05:14:58 am
Guess I'm not too patient. I see some unrelated video and I just closed it.
Yeah we'd need to see what this mysterious regulator with "some caps & resistors" actually looks like, how long the wires are, etc. Probably losing regulation because of poor transient response.
And how the current was measured, with what, etc...
Post by: Seekonk on February 13, 2015, 02:12:01 pm
I would think the cap at the battery side needs to be a LOT BIGGER.  I suspect it can't handle the surge.
Post by: Dragon88 on February 13, 2015, 06:40:11 pm
What's the dropout voltage of the regulator? Is it greater than 0.9V?
What's the measured output voltage of your regulator circuit with a 0.5A load?
Post by: daveshah on February 13, 2015, 07:42:54 pm
I don't think that the regulator is an LDO - the data sheet doesn't even give a dropout voltage spec - so the dropout voltage is likely to be about the two volts or so. Have you measured what voltage it is actually outputting?
