- Heater glowing: Yes
- Intensity + focus: Fully cranked
- Voltage pin7-->pin3: 58.5 V
I noticed a funny thing.
When I held my ~ 100 MegaOhm-to-GND probe against pin3 "WE" of the CRT socket, I heard a very high pitched, barely audible, sweep of perhaps half an octave until the sound went away. I was able to repeat that 1..2 times, but then no more.
Now it's back to what it was before all along: I don't hear anything, like I would expect from a TV CRT around 16 kHz (which I still hear very well).
Should this thing have any sound to be "healthy" - is that already a clue, if I don't hear a thing?
Edit: Found a video where someone had a similarly old Hameg, and a comment mentions that they have early tantalum caps that are visually not recognizable as defect, with his device it caused X deflection to not work.
This thing seems to have some of them here and there: See picture, the brown blob in the center, is that one of them buggers, or did they already have the pearl shape they had in the 90s? (what is that brown thing, in any case?)
Edit #2: The HV board has some voltages written as copper on it, I checked them. Top left one is totally off, 267
instead of 175 V ! I have yet to look in the schematic what that is. It's worse. In the layout, the solder blob where I thought should be 175V is the end of R550 close to the board edge. That has a trace to the +260V test conenctor, so that can't be it. Must be the one to the right next to it - which measured 530V, argh! (in the schematic, below it, page 21, right half, left upper corner. Big fat R550 is dran as dottet line and horizontal, left to a heatsink. The real point them mus be below the left end of R550, i.e. R536, which is also connected to T512 on that net. T512 is on the bottom of the page, center, above 4-diode rectifier. That would be a "+140V" rail then, on which I measured 530V... why does the PCB label say 135V then, and why is my 140+V test connector pin okay...
I'm confused.
Ok - I want to slap the guy who made the circuit. There are two different transistors, one TO92 (left edge, slightly below center), and one TO126 with screw hole (right edge of board, higher than center), on page 21 on the layout.
Why would anyone call two parts the same designator?! Argh. Need to check this out further, but it's clear that the TO with the screwhole is the 140V refulator and the little one where
I measured > 500V I need to find yet in the schematic. DUH, the "m" in the "mV" on that little "ANENG" DMM was so small
Still don't get that abou the supposed 175V where I measure 267V, though.
I saw that the read panel as apparently a deflection signal output on the rear panel. I hooked up my regular scope.
All I see is a constant voltage, which I can adjust, with the "X Pos" pot, between close to 0...60V. I played with all the knobs, there never is a sawtooth signal.
If I enable Hor.Ext ( = XY mode ?), the screen is no longer totally dark - it has a gray glow on the whole surface, and I can adjust the brightness of that glow by the left channel's amplitude knob. Then, I can move that glow, as if a dim flashlight with lens was held behind the screen and moved, out of the screen either top or bottom, depending on which direction I turn the left "Y Pos" knob.
Also, with above setup (XY mode on but no signal) if I turn the focus knob fully clockwise, the whole screen glows gray. If I turn it fully opposite, only a smaller radius at the right edge of the screen glows - see fotos.
From the top foto you can also see the front of the screen glow.
