Hi everyone, this HMI flickered then the magic smoke come from it.
I track the input voltage on the pcb all good to the td1501sadj buck converter output, what confused me is the burned zener diode with zero ohm resistors!, and I found burned chip witch i can't find datasheet for it (U6) (1102A/AAC?),
I need some help finding datasheet for it and (U9) (gh158/502MI) also I wonder why and how zener with zero ohm!.
Thanks everyone in advance
