How did you came accross? The type number is nowhere near SPS3414 from the parts list.
A lot of test equipment was sold the the US and other governments and one of the conditions of those sales was that parts and service information would be available. There is a system for parts where they are organized and given a number, called a NATO Stock Number or National Stock Number, abbreviated to NSN. There are surplus part companies that buy up this stuff and if you just do a google search for a part under the HPAK/Tektronix/Fluke/etc proprietary part number, you'll get hits that include the NSN from NSN resellers. Some of those will list a cross-reference of part numbers that have the same NSN--many of those 'proprietary' parts are just relabeled and not so special. In this case SPS3414 gets you an NSN of 5961-01-005-9745. If you dig a little, you will find this page:
https://www.nsncenter.com/NSN/5961-01-005-9745And you can see that one of the cross-references is a more generic part number, MPS-U45.
MPS-U45 can then be cross-referenced in the usual manner. It is available as an NOS on eBay and it crosses to NTE272. However, I like to check Central Semiconductor as well because they are an excellent, reliable source for a lot of 'trailing edge devices in legacy packages'. Their parts are available through regular, reputable suppliers so that you don't have to deal with 30-year-old or counterfeit parts and they don't gouge your eyes out like NSN-suppliers will. NTE Parts Direct has the NTE272 for $36.34 USD. Mouser has the CEN-U45 for $ 2.73.
As you go through this process, you do have to check the datasheets and make sure that there hasn't been an error somewhere in the chain, otherwise you may end up with a triac instead of a J-Fet or some other ridiculous result.
