Author Topic: Home made power supply restoration... In memory of my dad  (Read 698 times)
Offline tchiwamTopic starter
« on: May 07, 2021, 06:27:41 pm »
I remember when my dad was building it.
By the number of holes in the case, this was repurposed a couple of times since the early 80s.
Still works. The TO3 don't have much writing on them so making the schematic of it might be a bit hard.
The volt meter is pretty much right on the money...
The following users thanked this post: Ed.Kloonk
Offline bob91343
Re: Home made power supply restoration... In memory of my dad
« Reply #1 on: May 07, 2021, 10:16:51 pm »
It's a shame to see so much unused space.  A bigger transformer, for instance, or more filtering maybe.
« Reply #2 on: May 07, 2021, 10:36:19 pm »
I agree. I know the 2nd hole was for a current limit. So I was thinking to add that part of the circuit.
The shunt is just a wire running around the Amp meter...
Floating negative would be fun too...
Cleaned it a little more and replaced the power cord.
The transformer is a Basler something, I need to check the rating.
Edit away stupid autocorrect...
« Last Edit: May 07, 2021, 11:46:11 pm by tchiwam »
