I have this oscilloscope and I've just found that with every powering up the time is always the same (22nd October 2015, 8:43 pm). I saw EEVblog #144 where I can see (probably CR2032) backup battery soldered on PCB. Do you also think that the battery is dead ?
Another question: I'm going to replace it with a new one. Do I have to solder some temporary power supply instead of that dead battery to not lossing some data in some memory (like some old HP/Agilent which lost calibration data when battery was disconnected) or it doesn't matter in this case ?
