Author Topic: Hot tub controller trouble  (Read 506 times)
Offline laban93Topic starter
  • Country: no
« on: November 22, 2023, 11:30:34 pm »
Hi all!
I have some issues with my hot tub controller. It works for 4-5 days, then freezes and the tub goes cold. Its irregular when it happens. I must turn it off for 5 minutes then back on to get it working. I also noticed that the LCD backlight was dim, and sometimes not working. I did try to fix it by re-capping both the controller pcb and the main pcb, but nothing changed.. any ideas of where to start looking? Or anyone with any experience fixing theese?
HEAVEN - A place full of everything you get sent to hell for.
Offline Runco990
Re: Hot tub controller trouble
« Reply #1 on: November 23, 2023, 06:23:02 pm »
As someone who has fixed his own hot tub last year, have you looked at the control PANEL?   I thought I had a bad main controller ($2000!!!) but it was the control panel that had corrosion in it.  Seems they are not as sealed as you'd think.
  • Country: no
« Reply #2 on: November 23, 2023, 07:48:34 pm »
Yeah. I opened it and resoldered the connections and recapped. Did not see anything obvious though. It previousley had water intrusion trough the cracked membrane. Fixed that by silliconing a thin sheet of plastic as a second membrane. But yeah, there is no OBVIOUS faults.. When it freeze the buttons still work to control the jets etc, but the screen and heating turns off.
Offline fzabkar
« Reply #3 on: November 23, 2023, 09:26:04 pm »
It seems that the backlight might be a clue. Can you trace the circuit in this area?
