I’ve been using an inline isolation transformer to eliminate hum on my sound system after months of unsuccessful troubleshooting.
I conpletely dismantled, rerouted and replaced some inferior cables this week so took a serious look for the culprit through sequential connection of all the many components; Preamp, sub crossover, two subs amps, power amp, TV, sound bar, Blu-ray, CD, FIOS set top box. Found the offending item.
The only device with 3-prong grounded power is the power amp. After plugging in all devices to mains and still no hum, I thought I inadvertently solved the issue until I plugged the FIOS coax into the set top box.
Aha! I thought. Lift the ground on the demark. Nope. 2 prong plug, no ground.
Demark feeds the FIOS router as well, but it’s DC. I’m out of ideas. Is there such a thing as a coax cable isolation device? Yes I can lift the ground on the power amp but it is an all-metal case that is grounded and I’m unsure of the wisdom of lifting it.
Help!
Jeff
