I'm refurbishing a commercial convection oven, and the pcbs have some grease really baked on. My first hunch is an ultrasonic cleaner, but unfortunately that's not a viable option. I've tried my typical go-to solutions:
-toothbrush
-cue tips
-a few other plastic bristled brushes
-100% isopropyl alcohol
-acetone
-electrical contact cleaner
To no avail. I considered possibly soaking the pcb in acetone or alcohol, but decided not to because I'm worried that may delaminate or somehow damage the pcb. I have a reflow table w/infra-red lamp and considered this as well, but this also poses it's own challenge. I'm afraid that heating it up will only serve to smear and spread the grease. I have a variety of automotive cleaning solvents such as carb cleaner, brake cleaner, engine degreaser, etc etc, but have never tried to use any of them on electronics. Do you think that 1 of those cleaners may work? If so, what should I look for, and are there any chemicals that I need to be aware of that I should avoid? Any tips, suggestions, or advice is greatly appreciated.
