Likely some sort of induction motor - depending on power output, could be shaded pole (lowest power), split-phase, capacitor start, or permanent split capacitor, among others. Without changing the frequency, limited speed control is possible by varying the voltage. Otherwise it is as you say, a VFD will be necessary.
