Hi all,
I'm trying to fix a tiny little fluorescent tube driver circuit and it has this transformer in it. I made up a schematic symbol for it below to illustrate what I'm talking about. One side has 3 pins with the primary winding on the end pins. The other side has 2 pins with two secondary windings which meet up at the center pin on the opposite side. I've seen plenty of 5-pin transformers that have two windings and a center tap on the same side, but I've never seen one where their center tap is on the opposite side. I've included the wire diameter and the resistance of each winding but I have no idea how many turns are on each one, especially the inner winding with the thinnest wire.
How do I classify this transformer in order to find a replacement?
