I did try Deathwish link and if you had just clicked on "Get Manual" it would have worked without signin required.
But I get it, those websites for downloads usually have a ton of download buttons to get you to click on advertisers, The one he linked is not as bad as others though.
Edit: even if it's the same doc, I would still get his, because it seemed it was a better quality scan, but didn't look too much in detail so might be the same thing. Still worth your while to get both just in case.
