-This circuit is not designed by me, I am debugging this circuit.
-Because TP4 (S3), TP5 (S2), TP6 (S1) are connected to the analog switch chip, and finally connected to the AD chip, and then processed by the single-chip microcomputer, the output is cascaded with three operational amplifiers
-I didn't change the circuit, I checked the actual picture, the only difference is that the R33 (47K) resistor was removed, and the R29 (47K resistor value was replaced with 22K)
Because when I input 2dbm (0.282mv), TP6 has reached 6.006V, and then high, TP6 has not changed.
I want to get the correct change
