Seems to me that searching on AWM 20624 should get you results. AWM is a standardized means for marking component/appliance wires. I don't know whether type 20624 already specifies the pitch. If it does, you'd still have to find a source with the right length and number of contacts/wires.
80C is the temperature rating of the cable material, or 80 degrees C. 60V is the voltage rating of the cable material, or 60 volts. VW-1 is the flammability rating of the jacket material. The reversed RU is a variation of an Underwriters Laboratory marking. Bando - SH is likely some form of brand marking, but that doesn't mean you can always find them or buy from them as an end customer.
