Author Topic: [SOLVED] 5 pin 5V linear regulator identification/compatible replacement  (Read 1501 times)
Offline abyrvalgTopic starter
Could somebody help me identifying a regulator from year 1995 Jeep Wrangler ECU? Or perhaps just point me to something compatible.
Marking says:
49365A 403-2
MAL
2616
023M01
CS9517J
This regulator supplies a 5V CPU section of the ECU, providing some signal (POWERGOOD to nRESET?) to the supplied CPU.
This is a 5-pin TO-220 IC with this pinout (left to right):
1 - Vin (car 12V)
2 - POWERGOOD, connected to CPU nRST - this is a guess, has an external pullup
3 - GND
4 - ? - connected only to a big ceramic cap to gnd
5 - Vout
All this looks very similar to MIC29301 and brothers, but has a different pinout. If I’ll not find out a pin-compatible ic I’ll use MIC29301 bending it’s legs a bit.
Edit: attached an image
« Last Edit: October 21, 2018, 08:25:40 am by abyrvalg »
Offline langwadt
Re: 5 pin 5V linear regulator identification/compatible replacement
« Reply #1 on: October 21, 2018, 12:47:43 am »
Marking says:
49365A 403-2
MAL
2616
023M01
CS9517J
1 - Vin (car 12V)
3 - GND
5 - Vout
http://users.tpg.com.au/users/p8king/files/l487.pdf ?
The following users thanked this post: abyrvalg
