I'm working on a Roland SH-09 synth, I can't get a steady note from it. I've recapped, replaced some crusty trim resistors, cleaned the keyboard bed, torn down the faders and cleaned them out, each step has improved my measurements, but it's still not rock steady.
At this point I feel I've isolated the issue down to a Fairchild µa726HC temperature controlled differential pair. The control voltage coming in is steady, but the wave form coming out will bounce above and below the note frequency by up to 5Hz, and after 10 minutes of being on the frequency generated will drift up to 50Hz.
I tested the transistors in the package, both seem to be fine, test method was using the diode tester on my meter (Fluke 87V if it matters). I tested the resistor that is tied to the temperature control pin, it reads dead on. I was wondering if the AC in my shop was effecting it, so I placed a piece of foam on the package like a hat, same issues.
Any thoughts on how to properly test it? Are these known to fail with age?
I would just buy a NOS one and swap it to see if that fixes the issue, but the cheapest I can find them are on eBay for $95 plus $25 shipping, which is a bit much for a potential part that just sits in a part bin until I die.
Link to µa726HC datasheet:
https://www.alldatasheet.com/datasheet-pdf/pdf/54850/FAIRCHILD/UA726.htmlLink to SH-09 service manual (package can be found on page 4 in the VCO section):
https://www.synthxl.com/wp-content/uploads/2018/02/Roland-SH-09-Service-Note.pdf
