Thanks. I did know that EPROM erasing lamps are dangerous, but just not how much, and I didn't know about the skin hazard (which on second thought should be obvious of course, given that too much sun exposure is dangerous to your skin).
I built mine into a metal enclosure with a loose tray underneath where I put the EPROM(s), then I put the box on top of it. Not exactly failsafe with safety interlocks, but with common sense there should be minimal exposure towards myself.
There is a small (1cm diameter) hole on the end of the box which does allow some of the UV-light to come out, but I don't look straight at it, it doesn't reach far and I try to keep physically away (a couple of metres) from the box when it's on. Is that safe enough, or is just seeing any of the light harmful?
Without the tray I can put it right above the PCB, resting on the components although that won't totally block out all the UV-light coming out of it. Maybe a towel over it will help considering exposure might be for just a little bit. From what you're saying here I'm assuming that 4W of that light will cure in just a few seconds?
I don't have any other UV-light source unfortunately, and for this one time job of fixing a PCB it would be good to use what I already have. If not however I'll look for a "regular" UV light. Are "blacklights" the types used in discos and such, and that's what is safe to use for this sort of thing without any eye/skin protection?
