Author Topic: How to verify a PID controller board  (Read 283 times)
Offline capocasaTopic starter
« on: February 07, 2025, 05:41:08 pm »
Hello!
I have the attached PID controller board for coffee machines. It's a sort of simple device based on an atmega micro, a bluetooth board and some triacs to do the switching, and a temp sensor for the boiler.
My issue is that after putting it into the machine, the bluetooth serup works but the water does not heat when it's supposed to.
I am unsure how to verify the device works.
My thinking is to verify the triacs using a transistor tester, and then connect it outside of the machine with secured cables and use a multimeter to check if the expectage voltage is output to the correct outputs.
But before doing that, I'd love to know if you think I should be doing something else. Thanks!
Offline Poroit
Re: How to verify a PID controller board
« Reply #1 on: February 08, 2025, 06:02:15 am »
G'day capocasa,
Have you checked the heating element is intact by measuring its resistance?
« Reply #2 on: February 08, 2025, 08:36:09 am »
Hello!
No but it works using the regular thermostat. Bit I'll remember I can do that, thanks!!
