I obtained old 1280x1024 LCD screen,its Belinea brand,it looks like something from 2002-2006 year.There is one very weird thing about this acient LCD,it starts to make buzzing tone once its brightness setting is set bellow 73.
Literaly you can set it to any brightness from 73 to 100 its dead quiet,but once its bellow it starts to make buzzing tone,it sound like 1000 Hz square wave.As you set it to lower and lower brightness,the tone gets lower and between 73 and 60 it gets louder.Is this perhaps some old capacitor used in PWM control of the brightness that due to age gets piezoelectric,or starts to vibrate due to age?
What component,probably in PWM circuit can start buzzing at switching frequency due to age? Correct me if I wrong,but only widely used component that buzz is there cheap high capacitance ceramic capacitors,but I doubt its been buzzing like this from factory.
EDIT: Using the monitor right now,its smells little bit like burning plastic around it,kind of like before my previous monitor started burning.
