Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Metcal MX-5000 repaired for not heating up
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Metcal MX-5000 repaired for not heating up (Read 3442 times)
gregpl
Newbie
Country:
on:
October 21, 2017, 07:41:33 pm »
Didn't see this posted anywhere so thought it might help someone one day.
Was using my metcal mx-5000 and turned it off to replace tip then it wouldn't
heat up anymore. Everything else would work. When I picked up the iron to use
the bar graph did nothing and of course would not heat up.
Took it apart and found SMD diode D12 bad. SK16 -
https://media.digikey.com/pdf/Data%20Sheets/Diodes%20PDFs/SK12-SK16.pdf
Replaced the diode and its working again. Almost bought a new one. Glad I took it apart.
Logged
Zucca
Zucca
Supporter
Country:
EE meid in Itali
Re: Metcal MX-5000 repaired for not heating up
Reply #1 on:
October 23, 2017, 08:40:59 am »
Thanks
gregpl
, great job!
Logged
memed
Contributor
Country:
Reply #2 on:
November 07, 2017, 08:03:21 am »
Hi.
I have same issue with my MX-5200.
Did Q4 MOSFET was heating up that time?
Diode D12 was shorted?
Thanks
Logged
gregpl
Newbie
Country:
Reply #3 on:
November 07, 2017, 02:15:17 pm »
I used an IR camera and could see D12 getting hot. It read shorted. Replaced it and its working now.
I didn't check any voltages or anything else. Just used the IR to see if anything was getting hot.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
