Author Topic: HP 16700/16702 Power supply repair  (Read 843 times)
Offline dxlTopic starter
« on: September 04, 2021, 08:41:10 pm »
i've got my hands on a HP16702A Logic Analyzer. Unfortunately, a few seconds after power on the Power supply died. It looks like there's a small standby power supply in these units. An unknown TO220 Mosfet(?) bursted, so i can't read any part number anymore. I've attached a Picture of the PCB with the missing part. Does anyone know, what this part is?
What is strange is that Pin 2 connects to GND, and Pin 3 connects to the small standby transformer. I would have expected it the other way round.
« Last Edit: September 04, 2021, 09:24:21 pm by dxl »
Offline bob91343
Re: HP 16700/16702 Power supply repair
« Reply #1 on: September 04, 2021, 11:02:28 pm »
Perhaps an IRF840 or similar part.
Offline FrodeM
  • Country: no
« Reply #2 on: April 25, 2024, 08:04:56 am »
Not sure if you figured it out, but it's a TOP227Y integrated switch and regulator. You can see the schematics around this part here:
https://bitsavers.org/test_equipment/hp/167xx/Celestica_7000_Aux_Power_Regulator_Schematics.png
Note that 360V might not be correct. I have since figured out that the high-voltage side that source all of this is generated by a boost-converter regulator, not just rectified power-grid voltage. It is more likely something like 400V, but I have not measured it. Also make sure to check D7 down at the main board, this is by far the weakest link in the main current-path of the PSU.
« Last Edit: April 25, 2024, 11:48:56 am by FrodeM »
