Author Topic: HP 16702A does not recognize mouse  (Read 999 times)
Offline nikodemTopic starter
« on: July 22, 2020, 10:57:40 am »
I have recently acquired an "untested" HP 16702A logic analyzer mainframe, planning to repair it if it's not DoA. And it's not (except a blown-out cap in the mains filter).
Now i try to boot it to make some more elaborate self-test, but it does require a mouse, in order to boot its GUI. I have connected a PS/2 mouse, but it does not reckognize it (there is no problem with a keyboard). Does HP-UX need any particular type of a pointing device?
Thank you in advance for you help  :-[
Offline oPossum
Re: HP 16702A does not recognize mouse
« Reply #1 on: July 22, 2020, 11:36:32 am »
Adding a couple of pull-up resistors may get it working.
https://www.eevblog.com/forum/testgear/hp-16702a-mouse/msg374967/#msg374967
« Reply #2 on: July 22, 2020, 12:19:52 pm »
Thank you, but unfortunetely my unit has Rev.A of this board with no place for pull-ups (see image). Do you think, that just pulling up data and clock lines will be sufficient? I'll try to do that (maybe in the mouse, not in the 16702a).
EDIT:
I've added the resistors (1k) to data and clock line in the mouse but it did not help. I've ordered another mouse in order to see if it will work or not.
« Last Edit: July 22, 2020, 03:23:09 pm by nikodem »
Offline z80tw
  • Country: tw
« Reply #3 on: July 26, 2020, 09:57:58 am »
A regular PC mouse won't work on HP16702x logic analyzer,better to try an Agilent mouse,
I found this Agilent mouse worked on my 16702B( and PC) very well(I no longer have the 16702B),
it's an USB optical mouse with high resolution.
Offline Gerhard_dk4xp
« Reply #4 on: July 26, 2020, 11:40:59 am »
On my 16702B  a Microsoft IntelliMouse 1.2A works. It still has a ball.
Other identifiable text strings:  PN X04-72167   Product ID 63618-OEM-0290854-7    5199 (probably date)
There were other mice that looked similar with the same green PS/2 plug
that did not work.
Cheers, Gerhard
Offline oPossum
« Reply #5 on: July 26, 2020, 01:26:50 pm »
I use a Kensington model K72215 with my 16702A and 16702B.
Online coromonadalix
« Reply #6 on: July 26, 2020, 01:51:31 pm »
Same thing  for another insrument,   some mouse brands dont work well,  you hae to find the right one,     got an intellimouse too and a logitech   they work very well
