That's great, my Wife tell's me I am always in the middle of a disagrement. (lol)
I have a signal generator coming, I think I can borrow one to compare. I will reply back to the group when I get the instrument,
Just to be plain I just got my General Licence in Amateur Radio (KB9RVY) I wanted to use the scope in my radio room to do some minor repairs on old (Vintage Radios I have)
Again Thanks for the input.
Dan
If you have old radios around,you don't have to wait till your Signal Generator arrives.
The various oscillators in radios normally produce clean sinewaves.
OR
If you have a Dummy Load with a low level monitoring output,you can put a transceiver in the CW position,key it up on 160m or 80m,& look at the monitor output with your 'scope---this will be a very good sinewave.
OR
If your radio has a Crystal Calibrator,turn it on,adjust the receiver for an audible "beat" note,& hang your 'scope probe across the speaker or headphones.
Even radio receivers without a Calibrator often have "sprogs" at various tuning positions,so you could locate one of these & use it.
The audio "beat' note is a pretty good sinewave,& has the advantage that you can adjust it to 60Hz for a direct comparison with the Mains waveform.
