« on: January 22, 2019, 05:01:23 am »
Hey Guys,
I have project I am working on and wondered if I could get some input on these locked tuning knobs.
The fine tuning knob was locked tight.
I applied some penetrating oil to the shaft but can only get this shaft to rotate with a pair of vice grips. Replacing the knob just leaves it impossible to turn.
Is there a lubricant that will get in there and loosen this shaft?
Had a similar problem on a HP Sweep Oscillator of same vintage, that knob stayed a bit stiff after unlocking but it could be moved.
Logged
Tektronix TDS7104, DMM4050, HP 3561A, HP 35665, Tek 2465A, HP8903B, DSA602A, Tek 7854, 7834, HP3457A, Tek 575, 576, 577 Curve Tracers, Datron 4000, Datron 4000A, DOS4EVER uTracer, HP5335A, EIP534B 20GHz Frequency Counter, TrueTime Rubidium, Sencore LC102, Tek TG506, TG501, SG503, HP 8568B
