Hi All,
I have an HP-239A that works well and the THD measures low also. I thought I might try and calibrate the device as per the service manual section 5.11 (attached) but I am unable to get the frequency wwithin tolerance. At 10kHz I am always high and the best I can do is 10,069 Hz which is +- 10Hz as per specification. At 100kHz it is even worse and measures 92,296Hz. If I adjust C5 to match 100kHz my 10kHz becomes 10,916Hz.
Does anyone have experience in adjusting this device ? I note there is provision for an additional capacitor C45 (0-22pF) to adjust to 100kHz but that still won't solve my issue at 10kHz. I have no problems adjusting the gain per the manual.
Any suggestions welcome.
