I'm still try to repair my HP33120 Arbitrary function generator but after changing the main dac I have three problems.
- First I broke the vacum displa so I can't see nothing on the screen. Anybody know or have a display to sell to me?
(I found a seeler on ebay that sell the display only in US, unfortuannlly I'm in Italy, fuc......).
- The output amplifier is gone. Initially after replacing the main dac I saw I strange signal at the output, I did some check and found a burn resisitor, change it with a new one but after turning on the device it burn with smoke and now, after replacing it again, I see no signal at the output.
- The last problem is a little bit trick. When I power up the instrument I can change the frequency and I have a sine like the manual said.(I have the signal at the +AMP_IN and -AMP_IN on the board) but If I select for example a square wave I can't select back the sine wave. I heard the bip but I can't change the waveform. I have the same problem with the Freq button, so If I press the amp button I can't come back to the freq selection.
Of course If I had a display it would easier to know what is happening.
The two buttons are in the same column but If it was a column problem, on the display board, why the instrument beep when I press a button?
Wish someone can help me.
Best regards, Alberto.
