I picked up an auction lot of test gear from a university surplus sale a few months ago and never got around to testing anything till recently. (Apparently my ability to procrastinate knows no limits.)
In the mix were two function generators that were marked as faulty: an HP 3325B and a Wavetek 90. On a whim, I decided to try my hand at the HP first. (It was the lowest hanging fruit, seeing as it was at the top of the pile.)
I find performing a visual inspection before powering on to be the best policy when working with used gear that is known to have problems. After pulling the top and bottom panels off, the unit showed no obvious signs of damage or past repairs, which was a nice surprise. At this point I saw no reason I shouldn't try a power on test and noticed the fan turned on but the display remained dark. Thankfully no smoke or explosions were encountered during the test. However, I did notice the case near the pass transistors got pretty damn hot. At this point I decided to check the power supply.
To do this, you connect to power ground at pin 5 on J700 and then check either the test points TP200 +5V, TP300 -15V and TP400 +15V or J700 pins 1 (+15V) 2 (-15V) and 6 (+5V). The +-15V supplies looked okay (if a touch high) at +-15.1V but the +5V supply was pretty low at 3.4V. I figured the +5V supply was shorted somewhere, but to test that I needed to disconnect J700.
If you unplug J700, the function generator will not turn on since the power switch is connected through the front panel to A26 and then to A22 through J700. To fix that, you just connect J700 pin 10 (standby) to pin 5 (gnd). But since each supply has sense connections, you should also connect pin 1 to 2, connect pin 3 to 4, and connect either pin 6 or 7 to pin 8. After doing that. I saw that the +-15V supplies still read the same, but the +5V supply went up about 400mV. Okay. Looks like the fault is somewhere on A22. Better in the PSU than one of the other boards.
After examining A22 more closely I couldn't find anything that looked damaged--no discoloration, delamination or leaking/bulging caps. But the side panel got roasty toasty hot. At this point I decided to look at Q200, a TIP36A PNP power transistor which is used to regulate the +5V supply.
Conveniently, HP remotely mounted the pass transistors and used pins on the PCB with crimped wires to easily connect/disconnect them. After digging through my parts box I managed to find a TIP36C which has the same general specs but a higher breakdown voltage. Using a bunch of Pomona mini grabbers, I hooked it up and fired up the function generator to find the +5V supply reading 5.1V. Success! Looks like the pass transistor died.
Hold on there, cowboy! After pulling it off and comparing it with the replacement, I noticed that it actually looked good! Removing the junk box part and plugging the original transistor back in, with it still disconnected from the chassis, showed that indeed it was okay. The plastic insulator had turned brown from overheating, but the transistor itself hadn't given up the ghost yet. How curious. Looking more closely at the transistor showed that the insulator didn't actually reach the other side of the metal mounting tab. It looked like it was made for a TO-220 tab; unfortunately, a TO-218 tab is about twice as thick. So the mounting screw must have shorted the tab to chassis.
The rear panel around the BNC ports where an adapter is used to feed the option 001 reference back into the unit looks to be bent inward like the unit was dropped at some point. So maybe it got jarred hard enough to cause the mounting screw to nudge close enough to touch the mounting tab of Q200? Shit happens I guess.
Anyways, digging through my parts bin managed to drudge up a longer insulator. I also decided to swap out the original pass transistor since it had gotten pretty damn hot and looked to be a bit leakier than the one I found in the junk bin. Better to replace it and not worry about it dying later down the road--though that might be my paranoia talking.
Sure enough, when I swap in the new Q200 and mount it with the longer insulator the +5V supply is back in action. I then adjusted R352 so the supply voltages were within spec, as the +-15V were a little high previously.
Now was the moment of truth. I disconnected the remaining mini grabbers, plugged J700 back in and powered up the unit. Lo and behold, the display came on! Nice! Even better, I didn't see any error codes. Looks like it was just an improperly sized insulator.
Overall, this was a pretty uneventful, but still satisfying, repair. Another BER scrap destined for the recyclers or landfill was turned back into useable gear.
