Hi All,
I have a HP3335A that recently has started to give strange erratic problems (including missing display and unlocked msg) . All voltages are correct in the test points on the board, except the 10mhz reference board. PSUs works perfectly. I have +15v -15v -5.29v and +5v spot on. And the unregulated as expect.
Seems not cap depending (board has been already recapped recently) , it seems more cable dependent.
For example sometimes the display output disappears (1.000.000hz) and if I tap with the screwdriver on the 10mhz connector on the main board, it comes back.(well, until ytd, today not anymore even tapping)
If I leave the unit off, and restart after one day, again the display seems disappeared. Tracing back voltages, I do not find any of the +20V and +15V expected on the A17 board (the 10mhz temperature Stabilized oscillator board). This seems to explain the unlocked msg. Notice that when I was able to establish back the display, the voltages were still missing on the Temp. Ref. Board. So I would say the unlocked msg might be related to the A17/A10 board, but the display problem is bit of erratic. The fact that sometimes comes back make me think is not ROM memory dependant.
I will try to add an external reference now and see if I can at least check the behaviour with an ext reference.
The A10 board controller board that should provide the 20V+ unregulated to the 10mhz reference has only few IC (I think 2) but it's bit difficult to work
Has anyone got similar problems ?
Thanks for any help in advance.
