Author Topic: How to find this specific USB connector?  (Read 1501 times)
Offline GreybeardTopic starter
« on: August 18, 2023, 08:31:37 pm »
How do I find this particular USB connector from an HP Compaq 6530b notebook?
Preferred by cheap chinese on ebay...
What terms should I search for?
« Last Edit: August 18, 2023, 08:34:43 pm by Greybeard »
Offline thm_w
  • Non-expert
Re: How to find this specific USB connector?
« Reply #1 on: August 18, 2023, 10:02:10 pm »
Looks similar to this: https://aliexpress.com/item/1005005477104268.html
Not quite, but probably close enough to fit?
The following users thanked this post: Greybeard
« Reply #2 on: August 19, 2023, 12:14:45 pm »
Thanks, how did you find that?
Looks pretty good actually, but I think the contact plate is misaligned at 180°.
« Last Edit: August 19, 2023, 12:19:29 pm by Greybeard »
Offline wraper
  • Country: lv
« Reply #3 on: August 19, 2023, 12:21:30 pm »
It's not visible on your photos. Be aware that connectors like this come in different mounting depth variants. So you need to measure the exact depth needed, otherwise connector will fit on PCB but won't fit into enclosure.
Offline DavidAlfa
« Reply #4 on: August 19, 2023, 12:28:14 pm »
Have you tried searching the obvious, "HP laptop USB connector"? You'll have quite a lot of results but eventually they appear.
Maybe one of these fits:
https://a.aliexpress.com/_EzXCCdH
« Last Edit: August 19, 2023, 12:36:18 pm by DavidAlfa »
Offline lighting shade
  • Country: bb
    • Lightingshade-shades of light
« Reply #5 on: August 19, 2023, 12:44:48 pm »
Hello Greybeard,
To find a specific USB connector for an HP Compaq 6530b notebook on eBay or similar kinds of platforms, you'll need to explore using the right keywords. Here's what you can try: Mention the specific laptop model, which is the HP Compaq 6530b in your case, and specify the type of USB connector you need.The HP Compaq 6530b typically has USB 2.0 ports. Be sure to specify whether you need a replacement USB port or you are required cable replacement.
USB connectors come in various types and sizes. Most Probably The HP Compaq 6530b likely has USB Type-A connectors. Thus You are required to mention this in your search.
Determine whether you are required to choose a male or female USB connector. Male connectors have got pins, while female connectors have sockets.
« Last Edit: August 21, 2023, 11:58:01 am by lighting shade »
« Reply #6 on: August 19, 2023, 12:59:20 pm »
Yes, it's USB type-A.
I've tried USB type-A as keyword, but ebay almost always ignored this keyword (found also type-B and type-C).
I found some sketches and I tried to modify one to illustrate what I need:
« Last Edit: August 19, 2023, 01:10:51 pm by Greybeard »
Offline wraper
  • Country: lv
« Reply #7 on: August 19, 2023, 01:14:57 pm »
Look at aliexpress, not ebay. Also it's best to use incognito mode in the browser. Aliexpress thinks they know what you want better depending on your history  :palm:, and shows a bunch of irrelevant garbage instead of what you search. Using incognito fixes that.
« Reply #8 on: August 19, 2023, 02:44:43 pm »
I also tried AliExpress search from incognito browser mode.
Still shows mostly irrelevant garbage instead...
Is there no parameter search on a manufacturer's or distributor's website?
I mean parameters like USB-type, male/female, thru-hole/SMD, contact plate orientation, mounting lugs, etc.
Offline wraper
  • Country: lv
« Reply #9 on: August 19, 2023, 03:03:21 pm »
That's not how you search. You should be more general and then browse through the results looking for an image similar to yours, then look in to it further too see if it's actually what you want. https://www.aliexpress.com/w/wholesale-USB-connector-laptop.html?catId=0&initiative_id=SB_20230819065921&SearchText=USB+connector+laptop&spm=a2g0o.productlist.1000002.0
Offline wraper
  • Country: lv
« Reply #10 on: August 19, 2023, 03:06:56 pm »
This for example looks similar to what you need https://www.aliexpress.com/item/32834551466.html
Also when you find a seller selling similar stuff you can check the products they sell, often you can find a right one there.
Offline mariush
« Reply #12 on: August 19, 2023, 03:31:59 pm »
Thanks, Wraper.
I have also tried more unspecific search first, but found much garbage and a few USB connectors.
"This for example looks similar to what you need https://www.aliexpress.com/item/32834551466.html"
Yes, but the contact plate has to be 180° reversed.
After hours of searching, the required type could not be found ...
Offline wraper
  • Country: lv
« Reply #13 on: August 19, 2023, 03:41:08 pm »
This is literally what you described as correct.
« Reply #14 on: August 19, 2023, 03:47:51 pm »
« Last Edit: August 19, 2023, 03:51:35 pm by Greybeard »
« Reply #15 on: August 19, 2023, 03:58:56 pm »
I think you are right!  :-+
Sorry for my mistake, it is really hard to see the internal contacts on the photos...
I will order them.
Many thanks to all that tried to help.
Offline wraper
  • Country: lv
« Reply #16 on: August 19, 2023, 04:04:40 pm »
Desolder original connector and measure the dimensions, or at least try doing so without desoldering. As I said earlier, even if it will fit onto PCB, does not mean it will necessarily fit into enclosure. It may be elevated over the PCB more or less that original.
« Reply #17 on: August 19, 2023, 04:07:55 pm »
I'll try to get a dimensional sketch from the seller before I will order.
Offline wraper
  • Country: lv
« Reply #18 on: August 19, 2023, 04:32:25 pm »
There is a drawing with dimensions in the listing.
« Reply #19 on: August 19, 2023, 07:37:31 pm »
Thanks, in the meantime I found out I just had to scroll down.
But I have another serious problem now:
AliExpress do not accept my home address as shipping address.
The city is not in the drop down list and after using "other" I should be able to enter it freely, but it will just not accepted...
Entering the same address in "profile" as home address was accepted.
The AliExpress website is so f**king amateurish...   |O
« Last Edit: August 20, 2023, 08:47:34 am by Greybeard »
