Author Topic: HP-3421A Service Manual is required.  (Read 1000 times)
Offline youngwugTopic starter
  • Country: kr
« on: April 20, 2020, 02:23:33 am »
There is one HP-3421A that does not turn on (+15, -15, +5V is dead).
The measured value of C708 where oscillation is occurring inside the capacitor is 495(0.205).
C708(25V, 470uF) was replaced.
And when you turn on the power, +16.9V is measured in TP700, +7V in RT700, and +6.6V on top, regardless of S502(Switch).
However, +15V, -15V, and +5V cannot be measured.
I suspect the U702(LM393N, Dual Differential Comparator), but it is not easy to analyze because there is no circuit diagram.
If the “Wakeup Logic” on the left side of the figure can be related to S502, the problem is complicated, so I need a schematic.
Please tell me where to buy the service manual schematic(pdf or jpg).
Offline wn1fju
Re: HP-3421A Service Manual is required.
« Reply #1 on: April 20, 2020, 11:04:40 am »
Offline coromonadalix
« Reply #2 on: April 20, 2020, 11:37:01 am »
some links
3421A with only one ROM   talks
https://groups.io/g/VintHPcom/topic/27149599?p=Created,,,20,2,0,0::recentpostdate%2Fsticky,,,20,2,0,27149599
hp museum service manual attached
do a 3421a search,  will be easier to find what you need
thks @ wn1fju    never saw this website.
  • Country: kr
« Reply #3 on: April 20, 2020, 10:16:46 pm »
coromonadalix & wn1fju
Thank you so much.
It's best.
