Hello,
I also suggest to first check the +18V rail, and CR 203-A, before changing U201.
It's most probable, that CR203 ist toast, as U201-B obviously outputs >14V, which means that its supply is 15V at least.
If I remember correctly, these 5V1 of CR203 had been changed, (to 3V3
), so that depends on the version of your 34401A.
Do you measure reasonable values in the different 2W Ohm ranges?
I expect , that not only the 10M range or higher is defective, like Err. 612 suggests.
In the appended schematic, I have written down the nominal voltages for my working unit, 10M range with an external 10M resistor attached.
The printed boxes show values for a defective U201.
Frank
