Author Topic: Scantronic alarm - transformer replacement  (Read 2618 times)
Offline BicuricoTopic starter
  • Country: pt
    • VMA's Satellite Blog
« on: January 23, 2017, 10:29:27 am »
I own a Scantronic 9448 alarm system and the transformer got damaged - the coil burnt due to a current spike.
I went on eBay and bought a second hand transformer from a Scantronic 9600 system, which from the pictures looks exactly like the one I have. It has not arrived, yet.
Meanwhile, it occured to me to look at installation manuals for both devices and I found out that the Scantronic 9448 manual referes to a 21VAC intput connector from the transformer, while the Scantronic 9600 manual has a 19VAC connector.
My question is: what can possibly happen, if I connect the 19VAC transformer to my Scantronic 9448 board, which expects 21VAC? Is there like a +/-10% voltage tolerance? Or will the house burn down?
Thanks,
Vitor
Offline Muttley Snickers
  • Cursed: 679 times
Re: Scantronic alarm - transformer replacement
« Reply #1 on: January 23, 2017, 10:56:21 am »
It wont know the difference and I would be very surprised if it complained, most systems can run on anywhere from 16VAC to 22VAC and I've measured quite a few unloaded transformers/ power supplies/ plug packs output being much higher than the label without detrimental effects.
  • Country: pt
« Reply #2 on: January 23, 2017, 10:59:48 am »
Thanks for your reply.
I opted to ask the seller for a cancellation and he just refunded me.
I know nothing too bad would happen, but because this a house I am not living in, I felt even a minor risk was something I was not comfortable with.
Regards,
Vitor
Offline james_s
« Reply #3 on: January 25, 2017, 01:38:21 am »
The difference between 19 and 21V is less than 10%, that's well within the normal tolerance on something like that. Your line voltage may well vary more than that over time.
