34401a transformer voltages and impedances
Secondaries Voltages
reds only = 45vac
red and white = 22vac white being a center tap for te reds
oranges = 9vac
greens = 4.8vac
green and blue = 2.4vac blue being a center tap for the greens
Secondaries Ohms Values
green to green = 3.83 ohms
oranges = 2.28 ohms
red to red = 25.2 ohms
Primary Ohms values
100 vac = 45.7 ohms
120 vac = 54.6 ohms
220 vac = 119.5 ohms
240 vac = 132.3 ohms
I strongly suggest hot air station to removes any smt tantalums, the pcb traces may lift, remove the big electrolytics first, change the smt and put in last the big caps
I've done them in my 2 meters, just as a precaution, and put Nichicon caps.
