I recently won a Samsung 43in TV panel in an auction 15GPB but it seems that my bargain was short lived. When I plugged it in after getting it home, it came on, the Samsung logo appeared and it went to the menu. I connected my laptop and the desktop appeared. Everything looking good so I ordered the feet and a cheap remote for it. Total cost all in for the TV, 50GBP.
When the feet arrived and after I attached them, I powered it up again and this time, but this time there was no display, no backlight discernible. Only the standby light comes on. Pressing the power butting makes the light flicker momentarily but it stayed red. Today I received the remote and when I press buttons the red led flickers showing its receiving the signal from the remote, but still the display does not come on and it doesn't seem to be coming out of standby. Obviously disappointing as I can't return it to the auction house, but on the other hand every reason to open it up and have a look.
The first obvious thing were two bulging 470uf, 25V capacitors which will have to be replaced. I am not convinced that I am seeing anything under a flashlight except smudges but very hard to tell. The TV does not seem to have a separate T-con board or power and main boards. Everything seems to be integrated on one large board. It has two large ribbon connectors at the bottom. I tried disconnecting these one at a time, but no change.
I don't want to spend any more on this than necessary so I am thinking about how I can test the backlight without buying one of those LED testers? There are two pairs of wires that go to the connector so I assume there most be two circuits? When I check the output from the board it shows around 180V but starts collapsing quite rapidly over a few seconds as soon as I probe with the DMM. Not quite sure whether it should doing that? The 4.7uf, 500V capacitors adjacent to the LED test points do not bulge and physically look OK.
I did see a video online where a guy used 9V PP3 batteries in series, but without a current limiting resistor, so I am not sure that is safe, hence my question about how to go about testing the backlight.
