I was trying to use my Hantek scope to see the pwm waveform on a power supply and when I opened the software it went into demo mode
At first I thought maybe I deleted the driver by mistake because I was cleaning out some of the unused files and I did not see any drivers in the device manager or at least not with the Hantek name attached to it
I reinstalled the software and driver but it was still not doing anything when I plug in the usb
I plugged in my camera in the usb port and that is working so I know the usb port is good
After some research I heard about someone who suggested to remove diode D2 but I think that was on a different model but I did open up the scope and I measured D1 which is near the USB B port and it was measuring short
So I removed that diode and the short went away
I ordered a replacement but I was wondering if anything else could be wrong
When I plug in the USB I am getting about 3.8V from the cathode tab of the diode to gnd with the shorted diode removed
Would that be normal without the diode in place ?
Isn't the usb supposed to provide 5V ?
Would the computer be able to detect the scope without that diode ? I am guessing probably not
