I acquired this HP 3465A digital bench multi-meter from a local guy on Craigslist for $20.
I knew it had some issues before purchasing, but I was not aware to what extent until I got it home.
I opened it up and proceeded to take it apart.
That's when reality hit me like a brick to the face.
I did not take a picture of it at the time, but what I found inside was a battery block leaking and corroding everything it touched. The block was comprised of what appeared to be several AA style batteries.
I have no idea how many years those batteries have been inside the DMM leaking, but it was a mess. I managed to clean up the area where the batteries were installed. You can see that in the 2nd and 3rd pictures with the power switch and transformer. Unfortunately some of the traces where the battery block was installed are gone, but the majority of the corrosion has been cleaned off.
Now, in the rest of the pictures there are several components that are directly below where the battery block was installed, have been damaged. They all exhibit severe corrosion. I'm hoping to identify each component and its exact placement, then proceed to de-solder, clean the board and replace the damaged components with new components. I don't know if this will even be possible and if I will have to somehow rebuild any traces.
That said, once I removed the battery pack and cleaned up that PCB, I reassembled the DMM. But unfortunately I was unable to get it to power on. I'm not sure if there is something else damaged or just something I'm overlooking. I doubt those crusty batteries had any power left, and other than those batteries acting as a possible conductor, I have no idea how to supply power to the DMM.
Also, there appears to be some damage to the front panel. I have no idea what happened, but it looks like some sort of residue or permanent discoloration to parts of the front panel, specifically around the display and the input jacks. This is merely cosmetic and otherwise, besides the corrosion damage, there does not seem to be any physical damage.
I have not tested it any further. In fact, I'm actually looking for advice on how best to proceed. Maybe someone who has more experience than I do, specifically someone who has preformed those type of repair before.
