Author Topic: Hp 3468 lcd connector  (Read 834 times)
Offline Dan MoosTopic starter
« on: May 10, 2023, 12:14:02 am »
I'm replacing the screen on my meter. The connection on the lcd seems to be the same footrint as  standard 16 pin DIP.  Is there a connector that would friction into such a thing. The hole size seems exactly like what you'd expect if you were gonna solder an IC there. I remember the original cable (which I lost) just press fitting into the old lcd.
Re: Hp 3468 lcd connector
« Reply #2 on: May 10, 2023, 04:44:06 am »
I am looking for n something along those lines, but a press fit  into the lcd rather than soldering
The LCD has a DIP 16 pattern of through holes,  but I don't want to solder into them.  You can only get  to the top of the holes without wrecking the LCD.  I know I can solder pin into these holes and make a cable. I want something with pins I can just push in,  and have a friction connection directly to the LCD. This is how the original cable (that I lost) worked.
Offline Kim Christensen
« Reply #3 on: May 10, 2023, 05:26:11 am »
But that's what he showed you...
Maybe you want a premade cable? Not sure what the other end looks like though. Maybe take some pictures?
Offline Swainster
  • Country: sg
« Reply #4 on: May 10, 2023, 05:43:22 am »
Oh, I think I get it - there is no socket underneath - they are just a press fit into the PCB through holes? Hmmm, that's a bit "how ya doing" from HP. Sounds like you need something like solderless pin headers, also known as press fit (or hammer pin headers, because you can fit them with a hammer). I think that i'd prefer to solder my own socket and use the header that I suggested earlier... or even use a standard pin header and use the common crimp type IDC cable connectors.
https://www.samtec.com/products/pht
Offline Swainster
  • Country: sg
« Reply #5 on: May 10, 2023, 05:49:41 am »
Wow, didn't know you could still get those - that's really useful to know. The female cable mount connector seems way more popular, perhaps because its a little safer if it is accidentally left dangling on a PCB.
Offline coromonadalix
« Reply #6 on: May 10, 2023, 10:41:58 am »
its this one you need,  there was some disctutions about it
« Reply #7 on: May 10, 2023, 12:57:36 pm »
Yes Coromondalix! Exactly that! What is that called, and where do In get them!
« Reply #8 on: May 10, 2023, 03:44:08 pm »
so far only found theses
Part numbers:
Display - DSP1 - 5061-1166
Cable - W501 - 8120-3479
i do recall there was a few on ebay long time ago, but availability ????
