Author Topic: HP 3468A does not complete self-test, the LCD display all on.  (Read 1662 times)
Offline StrayElectronsTopic starter
« on: December 08, 2024, 08:49:25 pm »
Hi here,   First time posting.
S/N 2137A02728 and also the battery option 001 but I'll leave this battery's board disconnected via the ribbon cable at motherboard's also the lead-acid battery removed.   No leaks luckily.
I do have 5V (4.99V), +15V and -15V and ">7V" is around 12V.
The LCD display is all on including dots and commas as well instantly at turn-on.  Didn't exit the self-test.  Posted this picture.
I'm aware of basics to check for but I wanted to post here to get your thoughts.   I know this model does have ROM IC that usually develops bit-rot but wanted to check anything else first then suspect the ROM last.
I do have multi-meter and scope but I have to clear my crowded bench first.
Cheers,
Offline cruff
Re: HP 3468A does not complete self-test, the LCD display all on.
« Reply #1 on: December 09, 2024, 01:13:21 am »
That's the indication that it hasn't exited the self test, as you surmise. Do you have a copy of the service manual? It's available from several sites with a search.
Section 7-D-14 Self-Test says the order of the tests is ROM, RAM, cal RAM then the A/D converter. If all of those pass then the "SELF-TEST OK" message is displayed.
7-D-21 is the turn on failure trouble shooting section, there's lots of checks in that and the following sections to narrow down what might be wrong.
Online Tj138waterboy
« Reply #2 on: December 09, 2024, 09:47:01 pm »
It would be in your best interest to check out the rifa caps at the iec connector as well. NFM youtube video with replacement caps for a 3478a has link I used digikey cart https://www.digikey.com/short/72j411bn
« Last Edit: December 09, 2024, 11:26:58 pm by Tj138waterboy »
« Reply #3 on: December 09, 2024, 10:39:53 pm »
Thanks!   Do you have the laundry list of items in text?
Reason:
Clicked this and got the message: Due to restrictions, we are unable to add this item to your order
Cheers,
« Reply #4 on: December 09, 2024, 11:29:50 pm »
Sorry im working off mobile phone but I was able to cooy and paste web addrrss and it worked fine
« Reply #5 on: December 10, 2024, 03:16:01 pm »
I think this has to do with you account with Digikey's.
Do you have other way to export your list that is not dependent on account or list in text?
Cheers,
« Reply #6 on: December 11, 2024, 04:13:45 am »
P226-ND
BR-2/3AE5SPN
Panasonic - BSG
BATTERY LITHIUM 3V 2/3 A
Customer Reference
Immediate
5.59000
$5.59
Notice: This product contains Lithium. Air shipments and ship methods for the United States Postal Service are unavailable. Learn More
565-4098-ND
EKZN630ELL102ML25S
Chemi-Con
CAP ALUM 1000UF 20% 63V RADIAL
2.08000
$2.08
(2 pieces needed)
565-5008-ND
EKZN500ELL331MJ20S
Chemi-Con
CAP ALUM 330UF 20% 50V RADIAL TH
Immediate
0.93000
$1.86
(2 pieces needed)
399-5470-ND
R413F11000000M
KEMET
CAP FILM 1000PF 20% 1KVDC RADIAL
Immediate
0.66000
$1.32
(2 pieces needed)
399-R413I222050T1K-ND
R413I222050T1K
KEMET
CAP FILM 0.022UF 10% 1.5KVDC RAD
Immediate
0.62000
$1.24
Import Tariff may apply to this part if shipping to the United States
565-3928-ND
EKYB350ELL332MM25S
Chemi-Con
CAP ALUM 3300UF 20% 35V RADIAL
Immediate
3.05000
$3.05
Cart Summary
Subtotal$15.14
Shipping* $6.99
Tariff$0.12
Total* $22.25
* Estimates
FedEx Ground | 6.99
« Reply #7 on: December 11, 2024, 06:27:59 pm »
Hey,  Thank you for the list of components.
Cheers,
« Reply #8 on: December 15, 2024, 12:36:16 am »
Update:
All the voltages are good according to service manual including +/- 10V including buffered +10V, and three voltages 3.3, 2.2 and 1.1V on the pin 1, 2, 3 of the W501 for display.   I do have capacitor ESR meter and these 5 electrolytic  capacitors checks out, and all the silver axial capacitors are not shorted.
This multimeter is early version (eg does not have CR520) and seems to test digital circuits using programmed routines based on SA1 or SA2 via dipswitch 6 or 7.
SA1 (dipswitch 6 on) displays this way: LCD display flashing dimly every approx 1 second, means 1.3 second watch dog triggering on failure to reset the U504 IC on pin 2, which did repeatedly bounce the reset circuit for microcontroller U501 IC pin 4 cyclically.    Switch dip 6 off, stable with this reset circuit is held steadily high with display all lit up.
How this SA1 mode behaves make me to believe that display is not the issue,
Could be either digital section is jammed by other D/A, or latch IC or corrupt ROM IC.     I don't have resources to program new ROM IC have to ask someone to send me one for HP 3468A.
How reliable are CD4076BE ICs are?  These are part of digital bus and one of pin drives the watch dog counter.   What about the SN74LS373N is these known to fail?
Thanks and cheers,
« Last Edit: December 15, 2024, 04:31:39 pm by StrayElectrons »
« Reply #9 on: December 15, 2024, 08:39:49 pm »
Finally dragged scope out and had a look.
Checked clock and is beautiful sine wave, processor is working but 8 bit main data D0-D7 bus is horrible, slow rise but falling edge looks right and high frequency looking totally scrambled egg.  The small bus 4 bit bus pin 20 through 24 are clean sharp TTL waveforms.   Even I checked the latch IC U508 (SN74LS373) of input and output are also equally same garbage and U508 pin 11 is good nice waveforms.
Do I suspect the LS373 IC?
Cheers,
Offline cruff
« Reply #10 on: December 17, 2024, 01:11:43 am »
Can you unsolder and lift one or more of the D7-D0 input pins to the 373 and see if those signals clear up?
Offline fenugrec
« Reply #11 on: December 17, 2024, 01:25:08 am »
+1, either the source of those signals is defective, or something else on the bus is affecting them. I think you're close.
« Reply #12 on: December 17, 2024, 03:13:52 pm »
Lifting a pin I didn't thought of that!   Thank you, certainly I'll try that, but it isn't socketed, have to cut a leg.
Yes, I meant the inputs and outputs of this '373 are garbage.   Enable pin is clean.   The CD4076 in and outputs are clean.  And other than processor's D0-D7 are clean signals.
Cheers,
« Last Edit: December 17, 2024, 03:17:58 pm by StrayElectrons »
« Reply #13 on: December 22, 2024, 08:58:41 pm »
I'm still on trouble shooting.
The microcontroller is outputting bad quality signals,    Slow rise to high but on turn off going low is sharp and nice.
Does this HP3486A's microcontroller processor contains small ROM or just ram only?     Can I use intel 8039 or must I find a MK36000 microcontroller?   Which I cannot find MK36000 anymore on ebay.
Cheers,
Offline fenugrec
« Reply #14 on: December 22, 2024, 10:35:13 pm »
Hm, isn't MK36000 simply an EPROM ? In any case, the 8039 (also used in the 3478A which I have worked extensively on) has no built-in ROM or customization.
If you have an EPROM reader I recommend you (carefully) make a backup of the ROM chip, I don't know if anyone has dumped it yet, and the 3478A is too different to have compatible firmware.
« Reply #15 on: December 22, 2024, 11:53:04 pm »
My corrected.
Edited again, Eventually found what I'm looking for on Intel D8039"-6" means 6MHz version.
But did not find what I'm trying to find out what  "AHL" suffix means for Intel D8039AHL?
Thank you and cheers,
« Last Edit: December 23, 2024, 06:27:27 pm by StrayElectrons »
Offline cruff
« Reply #16 on: December 23, 2024, 05:54:40 pm »
The service manual says it uses a 6.003 MHz crystal.
« Reply #17 on: December 23, 2024, 06:32:10 pm »
I know because the service manual says this crystal is 6.003MHz.
But the other datasheets for D8039-6 is not clear till I found another datasheet after few days of search answered my question about "-6" meant.
The datasheet says intel processor without "-6" is rated up to 11MHz.
But I'm still not sure what "AHL" means for D8039AHL?
Offline fenugrec
« Reply #18 on: December 23, 2024, 07:43:48 pm »
For the 8039 : apparently nothing, see screenshot. I wouldn't worry too much, just backup your cal, get a "new" 8039, socket it, move on. That is, of course, if you're sure there's not another device on the bus that is shorting the Dx pins and causing the weird levels.
« Last Edit: December 23, 2024, 07:47:49 pm by fenugrec »
« Reply #19 on: December 23, 2024, 10:24:06 pm »
I rechecked and looked more carefully at data sheets and I'm now most satisfied with details I needed.
All the parts ordered are turned pin sockets, LP8039AHL processor, 54LS373.   Now I have to wait few weeks.
Once I have parts, and replace these and if that fixes this, will let you all with new updates.
Cheers,
