I am attempting to repair a 12V/4A PSU for my Buffalo Linkstation NAS drive. The drive failed to wake up automatically at a scheduled time. I swapped the PSU with a known good one, and the Buffalo NAS worked just fine. The initial test with that PSU under load looked okay with a multimeter, but on the Oscilloscope, it showed very high voltage fluctuation about 2V pp. So, I broke the power brick open to check, and found that the main capacitor was leaking and one of its leg was broken off. Besides that, PCB looked very clean and no burn marks. I replaced all capacitors on that power supply with new ones, and checked the switching MOSFET, voltage regulator (TL431), optocoupler and diode on the output side, everything looks just fine, however, the output voltage fluctuation didn't seem improved.
I then realized that this PSU is using the Fairchid PWM chip FAN7554, working under the bust mode. It turns off switching on the primary side when feedback voltage below 0.3V during the light load for saving energy. Such behavior causes the higher voltage fluctuations at no or light load. The circuit diagram of my PSU is almost identical with the example circuit in the Fairchild data sheet, See
https://www.alldatasheet.com/datasheet-pdf/pdf/51202/FAIRCHILD/FAN7554.html, except having very beefy filter capacitors, e.g. main capacitor is rated at 100uF/400V and output capacitors are at 1000uF/25V and 470uf/25V.
Understood of the limitation on FAN7554, however, the 2Vpp is still too much to me, although The PSU look like having a decent quality. I don't know the original specification of this PSU . But I don't think such voltage fluctuation is good for my NAS drive. I tested all components I can test, even ordered a new FAN7554, nothing helped to improve the voltage fluctuation for this PSU.
I would like to know how I can reduce the voltage fluctuation for the FAN7554 based SMPS.
Any help and comment are highly appreciated.
Thank you in advance!
