Hello everyone.
Returning after a long hiatus from posting. I've kept reading and watching EEVblog videos, but work has been rather unforviging this year.
I've recently adquired an used HP 34970a, with the 20 channel MUX and the DAC modules. It is working nicely so far, except for the usual 202 and 204 errors from the dead battery. Thankfully, no leakage in the PCB AFAIK. I don't really need a DAQ, but I wanted a 6.5 digit DMM, and this was the only device close to that which did fit my budget.
I have no means to calibrate a device like this, not even close. Apart from a few 0.02 voltage reference ICs and 4.5 digit multimeters, if the cal constants disappear, the device is most likely toast for me.
So I started looking around for a i2c programmer, and found this
https://whatever.sdfa3.org/hp-34970a-data-acquisition-unit-part-2.html and this
https://btbm.ch/8-pin-i2c-memory-programmer-with-arduino-uno/ links. Bought a few FM24C04-B and tested writing and reading them successfully. So, today, I dumped the contents of the external modules, starting with the DAC, as it is the least useful part for me. I tried to do it in circuit, as I'm still a beginner soldering, and don't have a hot air station or a desoldering gun. The results are attached as .TXT files.
After the (apparent) success, I proceeded to open the instrument and remove the DMM module to dump its F-RAM. So far I was assuming every FRAM had the address "0" on their A1 and A2 pins, and had them tied to GND. That was a mistake, as the one in the DMM has it's A1 pin (or was it A2?) tied to VCC (EDIT: It was A1, its right in the service manual). So I shorted VCC to GND and almost killed my arduino. Thankfully it shut down, and the instrument seems to be working well, despite the fail.
Now, when I opened the case just before the FRAM snafu and after having the unit plugged in standby, I noticed the dmm shield was rather hot, also, the plug-in modules and the transformer were warm. I don't have a mains power meter, but I measured the standby current into the unit and it was north of 40mA. That's 9 Watts, and seems a bit too high for a standby current, isn't it? I don't really know though, and haven't been able to find the standby power specified in the service manual or anywhere else for that matter. The transformer hums too while the unit is on standby, but I can't hear it over the fan while powered on, as it's quite low. I have it on 240 volts right now, but just measured the line voltage and it's more like 225-227V. It heats too on the 220V mode.
I attach a photo of the transformer, which seems to have some kind of burnt gunk in a thin line over the coils.
Now, I have to dump the main unit F-RAM, replace the battery (I might put a socket for a CR2032), and track down the idle power draw, if it's a problem. Maybe replace the fan too, but the unit wasn't used very much and it seems to be in good shape.
So, a few questions:
- Could someone take a look at the contents of the F-RAMs to see if they look right?
- I don't have a hot air station, is it a good idea to use low melting point solder with indium to replace the tiny SOIC8 FRAMs without overheating the PCB?
- Any ideas on the idle power draw? Whether it is normal or not, and any tip you could have to start troubleshooting.
Thank you very much.
Regards, Antonio.
