Let's start with fixing the device, which is the important thing, then I'm sure to do a decent calibration ... probably not at 2ppm, but to be used accurately enough at 0.01%
I can also have for DMM a 3458A, 34401, Kethley 2001 and Prema 5017 with short and good cables, it is not a problem for me to find the correct value, but to have a stable, non-variable standard. Obtained this, I can measure it exactly. The Bradley, after the correct warm-up, is sufficiently stable
However, nothing prevents me from having it calibrated, but I cannot bring to calibrate a faulty or out of specification device
