I just purchased an HP 3580A that had a working display prior to shipment to me.
However when I tried powering it up after receipt, I get no trace at all.
There are bulbs illuminated on the front panel, so I know it is getting voltage.
Although well packaged by the shipper, I suspect it had a rough transmit, judging by the nice sized hole in the cardboard box.
So:
1. What is the likelihood that the CRT was damaged?
2. What is the possibility of finding a replacement CRT, if it is the CRT?
3. What is the best way to rule out a bad CRT?
Thanks for any and all help!
