My HP 3585B is showing the error code "calibration error 17" when first powered up. This error comes up every time the unit automatically does a calibration. However, after it's been on for a while, the error stops occurring and calibrations go as normal. Once the unit stops throwing the error it never show up again until it's been off for a while.
The length time it has to be on before the error stops occurring varies with how much it has recently been used.
It can take anywhere from a few minutes to a few hours.
The manual is very vague about this error, saying it is on one of two circuit boards. These boards are large. I am using a GPS disciplined crystal oscillator for the frequency ref so I know it's not an issue with the oven controlled internal oscillator.
My wild ass guess is that it could be an electrolytic cap. My reasoning (ha!) is that very few parts get better over time and then don't cause any trouble until the device is powered down for some period. This seems like the behavior of an electrolytic cap that has failed and is being reformed when voltage is applied. I'm leaning away from a PS problem since the device works perfectly in all respects, all the time, except for the calibration after startup.
There are of course a ton of resistors, caps, discreet devices and IC's. In my experience resistors don't heal, nor do discreet semiconductors. I aware that IC's can do weird things but the fact that after the device has been on for a period and stops showing the error, it never occurs again no matter how long it remains on makes me doubt that an IC is the problem. I know it's a common trouble shooting
technique to apply freeze spray to individual components to see if that will show the failing component. But, I don't have any extender cards for these circuit boards and though I may have to make some,
the connectors aren't easy to source. It's a 1980s machine.
So I'm thinking of shotgunning all the PS decoupling caps on the two boards as a start. My experience with trouble shooting is mostly in analog circuits and mostly under
200kHz, though I do dabble in sub GHz RF.
I love this machine and it perfectly suits my needs. So I'm wondering what ideas anyone might have.
Thanks,
Spence
