I just noticed that exactly in the center there is a "cross like" dimmer/darker section. It pops up for a few seconds, then it disappears. If i change the channel its gone, when i switch back its there. As I said, it fine after some seconds.
Is this any sign of some catastrophic problems in the near future? Or could that just be the signal?
I'm using a external DVB-S2 tuner (via HDMI). The tuner of the TV is not used.
Thanks!
