Author Topic: what do you use to clean edge connectors?  (Read 1834 times)
Offline fabiodlTopic starter
« on: October 26, 2020, 11:33:39 am »
What do you use to clean edge connectors and other places where q-tips do not fit?
Offline tkamiya
Re: what do you use to clean edge connectors?
« Reply #1 on: October 26, 2020, 03:43:20 pm »
It really depends on exact configuration but I tend to use toothpick or wooden stick (used in ice cream making) wrapped with small amount of paper towel.  That with high grade isopropyl alcohol.  Uncoated business card material works well also.
« Last Edit: October 26, 2020, 03:46:58 pm by tkamiya »
Offline David Hess
  • DavidH
« Reply #2 on: October 26, 2020, 11:14:12 pm »
For switch contacts, paper which does not contain clay which is abrasive so like vellum or some card stock.  Alcohol is typically the solvent of choice but sometimes acetone is called for.
« Reply #3 on: October 26, 2020, 11:29:21 pm »
Four sentences, that's all it took. And I wonder why threads wander off track so often around here?  :)
For me: Generally, neat isopropanol wiped off with lint-free tissues (if I have them handy, kitchen roll otherwise). If that doesn't do the job, the reason is usually contamination that is water soluble but not soluble in non-polar solvents - in those cases I use a mixture of isopropanol and distilled/deionised water, wipe off, repeat if necessary, and finish up with neat isopropanol.
Extreme cases may call for use of abrasives and then cleaning as above. In that case the abrasive of choice for me is either a fibreglass pencil or one of the very finest grades of Scotch-Brite.
« Last Edit: October 26, 2020, 11:31:02 pm by Cerebus »
Offline helius
« Reply #4 on: October 27, 2020, 12:09:50 am »
I think a careful reading of the OP makes it quite clear he isn't talking about gold fingers, but the sockets that receive them. Those enclosed spring contacts are indeed similar to knife switches and other types of switches.
I usually use these: https://www.mgchemicals.com/products/electronic-cleaning-products/cleaning-swabs/single-head-chamois-swabs/ if the gap is wide enough. They are about 1.5mm thick.
Edit: There's also a similar swab from Electrolube if that is easier to get.
« Last Edit: October 27, 2020, 04:37:50 am by helius »
The following users thanked this post: fabiodl, opabob
« Reply #5 on: October 27, 2020, 12:27:15 am »
Ah, OK. The word "sockets" wouldn't have gone amiss then.  :)
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #6 on: October 27, 2020, 12:30:31 am »
Clean like get a bunch of gunk out of them, or just brighten them up to fix an intermittent (perhaps dusty or corroded) contact?  Contact cleaner works wonders, in any case.  Whichever brand name will do, I think; Deoxit is the famous one, but I have a can of MG Super Contact Cleaner which does a fine job as well.
Right, mechanical contacts are mechanical contacts, it doesn't much matter what they're there for.  A connector is a kind of long-range switch, you might say.
Seven Transistor Labs, LLC
« Reply #7 on: October 27, 2020, 12:36:15 am »
Thank you all. I use  kimwipes wet by 95% IPA placed on a card, and slide it in/out several times.
I am interested in cleaning both the contacts and the slot itself. I was looking for something exactly like the product mentioned by helius, thank you!
« Reply #8 on: November 20, 2020, 10:37:12 am »
I got them, they are thicker than I thought, about 2.2mm
They are relatively soft, and can be forced down the connectors, but not slided.
Offline CJay
« Reply #9 on: November 20, 2020, 10:59:32 am »
These or a variant of and a solvent/contact cleaner.
They're a plastic card (obviously credit card sized) covered with a lint free cleaning wipe surface, cut them down to suit the connector and ignore the price there, you can find them far cheaper
https://webstore.scott-law.co.uk/af-cardclene-atm-pos-magnetic-head-cleaning-cards-pack-of-20-ccp020
« Reply #10 on: November 23, 2020, 11:41:03 pm »
Thank you for the suggestion! I found them on aliexpress
Offline opabob
« Reply #11 on: November 26, 2020, 10:27:46 pm »
I use to use chamois tipped swabs for cleaning VCR's.  (Notice the name of these.)  I may still have some around.
Why did the Diode kiss the Capacitor.
He just couldn't Resistor
