Correct me if I'm wrong, but there still seems to be some confusion over the 403
A model, as far as I know it originally used single use/disposable batteries (400 hours operation), with
no mains power option and
no rechargeable battery option.
http://hparchive.com/Manuals/HP-403A-Manual.pdfThe TL431 seems a good solution, for both models, needs a bit of modification, as the 403
A model used two 4V batteries and three 1.3V batteries, all obsolete mercury hazmat type.
Or you could fit good quality NiMH cells, three cells to replace each 4V battery and single cells to replace each 1.3V battery.
Can't comment any further, as I only have the later 403
B model, one on it's own and another as part of the 3550A test set.
