Author Topic: HP 410C Meter pegs upscale Check A1R10?  (Read 188 times)
Offline wd5jfrTopic starter
« on: November 01, 2024, 08:19:07 pm »
It was working fine on resistance measurement, but then, after about 15 minutes, the meter pegs upscale, and the manual shows the possible cause as  A1R10 250 ohms. I think it's an intermittent cold solder joint or a failing 250 ohm resistor. At 84, my eyes aren't that good, so I need some help. If someone has an open unit, a picture or a description of its location would be nice.
Thanks
Hank
Re: HP 410C Meter pegs upscale Check A1R10?
« Reply #1 on: November 01, 2024, 11:09:25 pm »
Scott o n antique radio sent a pic here: https://antiqueradios.com/forums/viewtopic.php?t=442625
